inverted mesh problem
I just started learning COMSOL for my project. I am working on plane strain with fluid interaction module and it gives me inverted mesh error again and again. Could someone please tell me how to fix this problem.I would really appreciate any sort of help.
Thank you,
Manohar
2 Replies Last Post 20 lug 2009, 23:30 GMT-4
Posted: 2 decades ago 20 lug 2009, 18:03 GMT-4
from my understanding, inverted meshing is first of all a severe warning that he reasults may be quite wrong, and not only close to the inducated area, but not in 100% of all cases
For me it typically appears when I have not correctly "defeatured" my geometry, that is removed all unecessary small features such as screw holes, fillets, shamfers, badly aligned dxf (a format I hate because its not well defined/normalised, but its the only one really accepted in 2D).
So study your geomtry (and do this in your CAD environment its mostly quicker there), and learn to design in function of the FEM requirements, then add the "small features" for the manufacturing drawings afterwards.
Hi, from my understanding, inverted meshing is first of all a severe warning that he reasults may be quite wrong, and not only close to the inducated area, but not in 100% of all cases . For me it typically appears when I have not correctly "defeatured" my geometry, that is removed all unecessary small features such as screw holes, fillets, shamfers, badly aligned dxf (a format I hate because its not well defined/normalised, but its the only one really accepted in 2D). So study your geomtry (and do this in your CAD environment its mostly quicker there), and learn to design in function of the FEM requirements, then add the "small features" for the manufacturing drawings afterwards. Good luck Ivar
Posted: 2 decades ago 20 lug 2009, 23:30 GMT-4
Thank you for your advice Mr.Kjelberg I will look into that. That was helpful.
