10 gen 2010, 05:15 GMT-5
you do not give many details there, but singular matrix means mostly that you have not defined enough variables, are you suing material data that need extra variables, have you defined enough boundary conditions ?
Check your geoemtric and dependent variables, and find out if they are sufficiently defined by your boundary conditions, mostly the error would dissapear.
If not try to find an example on the web or in the doc, and start with that one.
7 set 2011, 01:33 GMT-4
hello...
i am having the same problem of - SINGULAR MATRIX.
i am trying to simulate a simple flow of a fluid in square tube.
i am using PDE mode, and i have mentioned all required boundary conditions.
pls help.
thanks a lot.
mainak.
hello...
pls help.
thanks a lot.
mainak.
9 years ago
20 apr 2015, 08:33 GMT-4
Hi,Ivar
I have some questions about the 3d grating compution. The first, does COMSOL simulate it successlly? So far, I havn't seen any report about it and I failed to get it. The errors like this so. So, if you can, could you give me a model.
Good luck.
Robertburns
Hi,Ivar
Good luck.
Robertburns
9 years ago
18 mag 2015, 04:11 GMT-4
Hi Ivar,
I am running a simulation where I determine a coil current with the use of global equations. The 2d simulation works but when I want the advance to a 3d simulation I encounter the Singular matrix error. You spoke of insufficient boundary conditions. What kind of boundary conditions am I not taking into account that make the difference between 2d and 3d?
Cheers Tom
Hi Ivar,
Cheers Tom
