19 gen 2012, 12:27 GMT-5
read the doc about Model coupling operators (Define Model Couplings integration) then define a variable "Definition - variables" calling this integration operator.
Solve or update your solution
post process in a plot or in a derived variables node
You might be able to define the full equation of your variable in a Global derived Variable node, but to refer to the integration you are better off defining them as operator first, then solve (to update the model data set) then display the results. The derived variables makes tables that you can plot out with a simple icon click
19 gen 2012, 13:05 GMT-5
Hi Ivar,
thanks for your reply; but I don't know what to do in the section "Results": practically, in the "surface integration" I wrote my equation:
1-exp(-1/((sigma0^m)*Veff)*((solid.sp1*(solid.sp1>0))^m+(solid.sp2*(solid.sp2>0))^m+(solid.sp3*(solid.sp3>0))^m)*Th_AsA)
But obviously, it solves an integral for this entire equation, and it's wrong, the surface integral is only:
Now, I tried to solve this integral with Results>Derived values>surf. integration and I was well about this; the problem is after:
1) How can I implement the remaining equation:
1-exp(-1/((sigma0^m)*Veff)*RES_INT*Th_AsA)
2) For the point 1), How can I call the results of "surface integration" as a variable (for instance RES_INT)?
Thank you again in advance, sorry for inexperience, it's one of my first approaches with Comsol!
Fabio
Hi Ivar,
Fabio
20 gen 2012, 01:42 GMT-5
indeed if you have a complex equation that requires the integral of a value over a surface and its combined with other variables, or other integrations, you need to do it in steps:
1) define your integrals in the definition node and have them prepared by solving or updating your solution (the solver node is lower in the three than the Definition node so changing anything "above" requires updates below)
2) define a variable that refers to your integration (as this is also "above" the solver node finish this part before your resolve or update)
3) use the Derived variables global evaluation and refer to the variables or to a combination of variables (COMSOL's internal ones as well as yours) and / or to the intop1() operators fully defined with the required expressions for the integrands. Then plot the resulting table
Note often you do not really need the Definition Variables, but such variables might also be referred to in all the other line surface or volume plots, but not the derived variables tables items
An important thing is to distinguish the variables (yours and COMSOL's) that are global and those who are implicit field variables with an implicit dependence on the spatial coordinates (x,y,z or r) and/or time "t"
20 gen 2012, 07:49 GMT-5
Hi Ivar,
thank you so much for your help! Now it works! But now I should improve my model, and so to use a Time dependent study instead of a Stationary, and I would evaluate this equation for each time (at 0 s, 10 s, 20 s etc); I have seen that the evaluation of a Derived Values is "manually" (practically, I have to click the = icon to see the result); this is properly for a stationary study (only one solution after the study), but for a Time dependent, in that I have a new solution after each step, how can I make it?
Thank you again
Fabio
Hi Ivar,
Thank you again
Fabio
20 gen 2012, 17:05 GMT-5
try it out, the derived variable nodes make lists for each time steps, these are the easy paces to make simple post processing. but you can also "define variables" (before you solve, or at least try a solver update F5) and refer to these in the plots. Most variables arein fact field variables depending on x,y,z and "t" when you have a time solver
24 gen 2012, 13:11 GMT-5
Yes, I have tried and works.
Thank you so much Ivar.
Regards
Fabio
Regards
Fabio
