Exporting java application to runnable jar file
Александр Ляпин
I am following COMSOL tutorial about making GUI app from Programming reference manual. Everything works fine when I am running application from IDE (eclipse), however when I am trying to export it as a runnable jar file and run from the command line (java -jar project.jar) I am getting exception:
Exception in thread "main" java.lang.NullPointerException at com.comsol.model.util.ModelUtil.a(SourceFile:44) at com.comsol.model.util.ModelUtil.initStandalone(SourceFile:396) at BeamModelDemo.init(BeamModelDemo.java:36) at BeamModelDemo.main(BeamModelDemo.java:227)
I've tried all options with exporting libraries (export, pack, copy to folder), but the result is the same. Does anyone can explain me the reason of this error? Or maybe there some source where I can read how to properly deploy comsol-java projects?
Thank you.
1 Reply Last Post 13 set 2020, 22:25 GMT-4
Hello Александр Ляпин
Posted: 4 years ago 13 set 2020, 22:25 GMT-4
Have you dealt with the problem well,I have the same problem as you
