Evaluate Impedance of a coil
Hello All, I am trying to include impedance calculations in my model.
To keep it simple, let's consider my model to be AC/DC analysis with a single conductor coil. To realize it I followed the example of ecore_transformer, so I did the coil geometry analysis and then I did the analysis in time-dependent (frequency is 50 Hz). I managed to trace arrows of the density of current and the induction magnetic.
Now I'd like to evaluate the impedance and inductance of the coil. I know that I should use a global evaluation under derived values, but there aren't these choices in default calculations for coil parameters. I can evaluate only other parameters like current, voltage, and resistance in DC.
Could you tell me why I can't find other default calculation? Thank you very much for your help.
1 Reply Last Post 19 apr 2020, 14:38 GMT-4
Posted: 5 years ago 19 apr 2020, 14:38 GMT-4
Impedance, admittance, etc. are only applicable to sinusoidal steady state. Do a frequency-dependent simulation, then these choices will appear.
> I did the analysis in time-dependent (frequency is 50 Hz) Impedance, admittance, etc. are only applicable to sinusoidal steady state. Do a frequency-dependent simulation, then these choices will appear.
