Plot 3D Graph for function c (x,t)
I have a transient problem in 1D geometry.
I found a solution as a function of x [m] and time t [s].
solution = c(x,t) ; c is concentration, x is distance [m], t is time [s].
I know how to plot a 2D graph for concentration c as a function of distance x at each time step.
How to plot a 3D graphics for concentration, with one axis is time and another axis is distance x ?
Thank you very much,
Dao Trinh
4 Replies Last Post 27 gen 2012, 18:19 GMT-5
Posted: 1 decade ago 27 gen 2012, 14:55 GMT-5
if you want a 3D "height" plot, you might need to export your data into an interpolation function (you might reimport it I beleive as a x,y Interpolation function and then use the GUI to plot it as a 2D XY plot with Y=t) or use Excel or matlab, as I'm not sure how to plot x,t like that (x,y is a standard 2D plot and there you can add a subnode "height")
Personally I plot 1D line plots "x" with multiple lines for such cases, never really tried what you are proposing
But I do certainly not know all the plotting tricks ;)
Hi if you want a 3D "height" plot, you might need to export your data into an interpolation function (you might reimport it I beleive as a x,y Interpolation function and then use the GUI to plot it as a 2D XY plot with Y=t) or use Excel or matlab, as I'm not sure how to plot x,t like that (x,y is a standard 2D plot and there you can add a subnode "height") Personally I plot 1D line plots "x" with multiple lines for such cases, never really tried what you are proposing But I do certainly not know all the plotting tricks ;) -- Good luck Ivar
Posted: 1 decade ago 27 gen 2012, 15:51 GMT-5
Thank you Ivar.
I want to ask the related problem. I got the solution c(x,t). And I want to get the value dc/dx at x=0 for all time.
I selected Result > Derived Values > Point Evaluation and Select the point x = 0.
And then I typed the Expression is : gradx_c
I got the Table Result, and it works.
My question is : Do we have another method to evaluate the dc/dx at x=0 ? Or the method proposed above is the only one ?
Thank you Ivar. I want to ask the related problem. I got the solution c(x,t). And I want to get the value dc/dx at x=0 for all time. I selected Result > Derived Values > Point Evaluation and Select the point x = 0. And then I typed the Expression is : gradx_c I got the Table Result, and it works. My question is : Do we have another method to evaluate the dc/dx at x=0 ? Or the method proposed above is the only one ? Thanks
Posted: 1 decade ago 27 gen 2012, 16:17 GMT-5
I've tried your method. Export the function c(x,t) as a txt file, and reimport the file in Comsol.
It works but not very good, it is hard in Comsol to change the the ratio of the axis. In my case, I got the 3D graph, but one axis is time (run from 0 to 1s) and one axis is distance (run from 0 to 20m). The graph is distort in one direction.
[QUOTE] Hi if you want a 3D "height" plot, you might need to export your data into an interpolation function (you might reimport it I beleive as a x,y Interpolation function and then use the GUI to plot it as a 2D XY plot with Y=t) or use Excel or matlab, as I'm not sure how to plot x,t like that (x,y is a standard 2D plot and there you can add a subnode "height") Personally I plot 1D line plots "x" with multiple lines for such cases, never really tried what you are proposing But I do certainly not know all the plotting tricks ;) -- Good luck Ivar [/QUOTE] I've tried your method. Export the function c(x,t) as a txt file, and reimport the file in Comsol. It works but not very good, it is hard in Comsol to change the the ratio of the axis. In my case, I got the 3D graph, but one axis is time (run from 0 to 1s) and one axis is distance (run from 0 to 20m). The graph is distort in one direction.
Posted: 1 decade ago 27 gen 2012, 18:19 GMT-5
if "c" is a dependent variable, there is a fair chance that COMSOL has already defined cx and cxx and ct ... (provided you have at least a 2nd order, or higher, shape function.
If not, there is a KB article about defining new equation to get more precise derivatives, its tailored for time derivatives, but why not also space derivatives, incase the firs hint is not possible.
Unfortnately I'm not by my COMSOL WS tonight ;)
Hi if "c" is a dependent variable, there is a fair chance that COMSOL has already defined cx and cxx and ct ... (provided you have at least a 2nd order, or higher, shape function. If not, there is a KB article about defining new equation to get more precise derivatives, its tailored for time derivatives, but why not also space derivatives, incase the firs hint is not possible. Unfortnately I'm not by my COMSOL WS tonight ;) -- Good luck Ivar
