Jim Freels
mechanical side of nuclear engineering, multiphysics analysis, COMSOL specialist
29 gen 2012, 21:37 GMT-5
Yes. COMSOL is using fully implicit time stepping throughout; hence, large Jacobian matrix is formed and used in the solution.
One word of caution that we ran into with the fluid/structure coupling (FSI) type simulations: If there is a frequency within the system that you want to capture in a time-dependent solution, you need to keep the time step small enough to capture that frequency. This would not be an issue for the steady-state. For example, if the fundamental frequency of the structure was 10 hz, you would need to keep the time step at less than 1/10 sec or smaller in order to visualize the results accurately in the time response.
29 gen 2012, 23:01 GMT-5
Thank you so much.
I wonder if you can help with other difficulty I've been going through. I am try to find the time in which the velocity of my model stabilizes. I ran three different simulations with a time step of 0.1 during 5 s, 10 s and 20s . However, I am obtaining the same answers for the three models, because COMSOL is giving me just the first 50 time step solutions, which means the answers for the first 5 seconds.
Is there something should I modify in COMSOL to obtain more data, or does it mean that after 5 seconds the model is stable and for this reason COMSOL is not giving me any more solutions?
Thank you so much.
30 gen 2012, 01:21 GMT-5
What kind of time stepping do you use ? if its the default "free" COMSOL assumes a diffusion type problem and the ime increments will increase regulraly (provided the slopes of the solving system remains more or less stable). If you expect oscillating BC's or responses, its worth to define a rahter short time step range (many steps to resolve the oscillations) and use a time stepping "intermediate or strict" this will certainly take longer to solve but you will be sure COMSOl considers the true response at your time steps and not giving you the interpolation between two loarge steps
