Error in running Wave Optics Study
Hello! I keep running into this error when computing my study. Any help would be much appreciated.
  • Feature: Stationary Solver 1 (sol1/s1) Division by zero.
  • Function: / Failed to evaluate expression.
  • Expression: abs(try_catch(comp1.ewbe.port3.Pin,1)/comp1.ewbe.Pmode_3) Failed to evaluate variable.
  • Variable: comp1.ewbe.tEmodex_3
  • Defined as: sqrt(abs(try_catch(comp1.ewbe.port3.Pin,1)/comp1.ewbe.Pmode_3))*comp1.ewbe.tE0modex_3 Failed to evaluate expression.
  • Expression: nojac(comp1.ewbe.tEmodex_3) Failed to evaluate variable.
  • Variable: comp1.ewbe.PortConstrx
  • Defined as: if((abs(unit_rad_cfarg(comp1.ewbe.beta_3))<=(0.25pi))||(abs(unit_rad_cfarg(comp1.ewbe.beta_3))>=(pi0.75)),comp1.ewbe.S3x,0)*nojac(comp1.ewbe.tEmodex_3) Failed to evaluate expression.
  • Expression: comp1.ewbe.tEx-comp1.ewbe.PortConstrx
2 Replies Last Post 20 mag 2020, 01:27 GMT-4
Posted: 5 years ago 19 mag 2020, 08:16 GMT-4
Please check the value of comp1.ewbe.Pmode_3 Is it equal zero? or non-defined?
Felipe Beltran-Mejia
Posted: 5 years ago 20 mag 2020, 01:27 GMT-4
can you attach your model file?
