Robert Koslover
Certified Consultant
5 years ago
15 mag 2020, 21:08 GMT-4
Updated:
5 years ago
15 mag 2020, 21:10 GMT-4
I'm not exactly sure what you mean by "extinction" or by the "remaining electric field intensity," but if you compute the electric field E in the presence of a dielectric, then the value of E that is plotted or displayed to you will be the electric field in the presence of that dielectric. You do not have to do any additional calculation to extract or correct the electric field that is computed.
I'm guessing that maybe by "extinction," maybe you are referring to something like the reduction in the electric field that would occur if a dielectric (epsr>1) is inserted into an isolated capacitor, while holding the capacitor-plate charges fixed (not holding the potential fixed). In such an example, the dielectric would cause the electric field in the capacitor to be reduced, because the bound charges in the dielectric shift. If that is what you meant, then as I said before, Comsol Multiphysics can and will compute the electric field properly within that bulk dielectric (assuming you set up the problem correctly, of course).
I hope that helps.
I hope that helps.
