5 years ago
3 giu 2020, 14:53 GMT-4
Hi Ming,
The variable Hxy should indeed give the derivative of Hx with respect to y. Thus, the current density in the z direction should be Jz=Hyx-Hxy as you suggested. However, I am not sure why you are getting a non-zero value for the expression mentioned above. What kind of value are you getting for the expression? Also, are you using a moving mesh?
Cheers,
Alex
Hi Ming,
Cheers,
Alex
5 years ago
3 giu 2020, 21:18 GMT-4
Dear Alex,
Thank you for your suggestion.
Firetly, I just use a triangular mesh, it's not a moving mesh.
And, I use the mfh part. The expression: mfh.curlHz-mfh.Jz is zero, but the value of mfh.Jz-(Hyx-Hxy) is from -2.56e-13 to 2.34e-13.
Yours,
Ming
Dear Alex,
Yours,
Ming
5 years ago
4 giu 2020, 09:25 GMT-4
Hi Ming,
This is probably due to numerical error rather than the definition of Hyx. Taking the derivative of the H field will lead to numerical error, and since the H field is usually on the order of 1e6 A/m, the error of 1e-13 seems reasonable. The reason why mfh.curlHz-mfh.Jz gives zero is that mfh.Jz is defined as mfh.curlHz, so Comsol recognizes that they are exactly equal.
Cheers,
Alex
Hi Ming,
Cheers,
Alex
5 years ago
5 giu 2020, 01:03 GMT-4
Dear Alex
Thanks for your suggestion. This helps me a lot. I was confused for days, now I can have a good sleep. Haha
Yours,
Ming
Dear Alex
Yours,
Ming
