Using the parameterized scanning function, how to use the statement ‘mphinterp’ to extract data of a certain coordinate under all parameters?
Hi All,
I have got some problem. Using the parameterized scanning function, how to use the statement ‘mphinterp’ to extract data of a certain coordinate under all parameters? Best Regards
1 Reply Last Post 9 giu 2020, 09:08 GMT-4
Posted: 5 years ago 9 giu 2020, 09:08 GMT-4
There are two types of parameter sweeps in Comsol:
1) Parametric Sweep (which is a separate studystep)
Use 'outersolnum' to specify which outputs you want
2) Auxiliary sweeps
Use 'solnum' to specify which outputs you want.
There is more information about these terms in the LiveLink for Matlab User's Guide.
Lars Gregersen
Comsol Denmark
There are two types of parameter sweeps in Comsol: 1) Parametric Sweep (which is a separate studystep) Use 'outersolnum' to specify which outputs you want 2) Auxiliary sweeps Use 'solnum' to specify which outputs you want. There is more information about these terms in the LiveLink for Matlab User's Guide.
