RF Modal Analyisis + Livelink: ploting other modes.
Hi to all,
as I've seen in the Livelink for Matlab introduction tutorial, a good way to learn to use Livelink is by saving the comsol file as an .m file and then opening it on the Matlab editor.
So far so good the file ran and finished without any error message. After that, on the Matlab's Command Window I'd executed:
>> mphplot(ans,'pg1')
and I get a beautiful plot of the last mode I'd calculated for the last parameter (parameter sweep for parameter 'M').
Unfortunately, I haven't been able to find a way to plot other modes for the same M (or for another value of M).
At the end of this message I'm including the last lines of my .m file, which I believe are necessary for you to know how I'm storing the solutions.
Cheers,
Felipe
model.sol('sol1').feature('st1').name('Compile Equations: Mode Analysis');
model.sol('sol1').feature('st1').set('studystep', 'mode');
model.sol('sol1').feature('v1').set('control', 'mode');
model.sol('sol1').feature('e1').set('control', 'mode');
model.sol('sol1').feature('e1').set('transform', 'effective_mode_index');
model.sol('sol1').feature('e1').set('shift', 'chute');
model.sol('sol1').feature('e1').feature('aDef').set('complexfun', true);
model.sol('sol1').runAll;
model.batch('p1').set('control', 'param');
model.batch('p1').set('pname', {'M'});
model.batch('p1').set('plist', '{1,0.8}');
model.batch('p1').set('err', true);
model.batch('p1').feature('so1').set('seq', 'sol1');
model.batch('p1').feature('so1').set('psol', 'sol2');
model.batch('p1').feature('so1').set('param', {'"M","1"' '"M","0.8"'});
model.batch('p1').attach('std5');
model.batch('p1').run;
model.result('pg1').name('Electric Field (emw)');
model.result('pg1').set('data', 'dset2');
model.result('pg1').set('solnum', '5');
model.result('pg1').set('outersolnum', '1');
model.result('pg1').feature('surf1').set('unit', '');
out = model;
1 Reply Last Post 16 feb 2012, 08:26 GMT-5
Posted: 1 decade ago 16 feb 2012, 08:26 GMT-5
Finally I found my way.
So I will answer myself here for future references:
Suppose you have your results stored under the variable 'model' with 6 eigenvalues, then, in order to change to the fifth eigenvalue (for example) you write in the matlab command window:
where pg1 is the comsol's tag you used to store the results at the end of your matlab script.
Now you can plot it:
mphplot(model,'pg1')
or print the results (i.e. the effective refractive index):
mphglobal(model,'emw.neff')
enjoy!
Felipe
Finally I found my way. So I will answer myself here for future references: Suppose you have your results stored under the variable 'model' with 6 eigenvalues, then, in order to change to the fifth eigenvalue (for example) you write in the matlab command window: model.result('pg1').set('solnum', '5'); where pg1 is the comsol's tag you used to store the results at the end of your matlab script. Now you can plot it: mphplot(model,'pg1') or print the results (i.e. the effective refractive index): mphglobal(model,'emw.neff') enjoy! -- Felipe
