Boundary conditions
Marie Seltveit Haugen
I was looking for the boundary conditions reradiating surface and surface-to-surface radiation, but I coulden't find them. I was looking in heat transfer module, but all I could use was surface-to-ambient radiation. I am using version 4.2 classkit lisence. Is it possible that I have a reduced version of it?
1 Reply Last Post 16 feb 2012, 10:57 GMT-5
Posted: 1 decade ago 16 feb 2012, 10:57 GMT-5
I am not familiar with the classkit license, but in general surface-to-surface radiation requires a license to the Heat Transfer module. Also it will only show up as an option in the popup menu of the heat transfer node if “surface-to-surface radiation” is selected (from the Settings window of the heat transfer node).
Nagi Elabbasi
Veryst Engineering
I am not familiar with the classkit license, but in general surface-to-surface radiation requires a license to the Heat Transfer module. Also it will only show up as an option in the popup menu of the heat transfer node if “surface-to-surface radiation” is selected (from the Settings window of the heat transfer node). Nagi Elabbasi Veryst Engineering
