Problem of contacting crack edges
Posted 17 feb 2012, 10:20 GMT-5 Version 3.5a 3 Replies
Hi everyone,
I am modeling a crack irradiated by laser source, which is represented by heat flux, and try to observe the closure of the crack due to the thermal expansion after the laser irradiation. I can have a very nice thermal expansion when the heat flux is applied in the beginning, but after crack edges touch, they keep moving, and finally "blend". In order to fix this problem, I was suggested to try to set both edges of the crack as "contact pair", however, Comsol reports error:
Error: 6170
Failed to evaluate variable.
- Variable: E
- Geometry: 1
- Boundary: 5
- Variable: pn_cp1_smpn
- Defined as: (E/h)
Failed to evaluate operator Jacobian
- Operator: if
- Geometry: 1
- Boundary: 5
Could someone help me with this problem?
Thanks!!
Error: 6170
- Variable: E
- Geometry: 1
- Boundary: 5
- Defined as: (E/h)
- Operator: if
- Geometry: 1
- Boundary: 5
Thanks!!
3 Replies Last Post 17 feb 2012, 14:32 GMT-5
