Robert Koslover
Certified Consultant
4 years ago
7 lug 2020, 00:06 GMT-4
Updated:
4 years ago
7 lug 2020, 00:19 GMT-4
If or when you see a reflection coming back from the end of a transmission line (TL), then that termination (port, if you prefer) is not perfectly matched to the TL in terms of its impedance. In general, the phase of the resulting reflection (as detected wherever you are looking) will depend on the distances traveled by the wave in going back and forth. See https://en.wikipedia.org/wiki/Transmission_line#Input_impedance_of_transmission_line .
Now, although I may not fully understand your question, it seems to me that you simply aren't terminating your cpw line properly. If you terminate it with an excellent impedance match, then you should not see a significant reflected wave, regardless of the length of the line.
By the way, I would expect that your termination will need to be equivalent to a R=50 Ohms resistor, rather than to some LC combination, at least assuming that your line has a "characteristic impedance" of 50 ohms (as opposed to some other resistance). L's and C's, if properly chosen, may be appropriate for modeling the line in terms of a circuit model (alhough personally, if I were doing that, I would use a traditional circuit modeling code like SPICE (https://en.wikipedia.org/wiki/SPICE) , instead of Comsol Multiphysics). But regardless, you'll need a resistor to model the (in effect, ideally lossy) infinite length of it, when you get to the end of the TL. Is that where you are having trouble? Are you trying to terminate the line in L's and C's alone, when you need to be using an R?
4 years ago
12 lug 2020, 12:57 GMT-4
Thanks for getting back to me, in fact I have lost this post and couldn't come back to reply until I saw your email.
I realized my question was very vagued, and later on I have found the issues of my model which came largely from my lack of understanding on how COMSOL works. With the help of your reference, I can now obtain results much closer to the theoretically predicted values for the artificial transmission line.
