Plot a solution from a dataset in Matlab (Solved)
I am using parameter sweep to solve a contact problem. Is there a way to get a plot data structure in the dataset other than the default last one?
Update: The visualization of a plot group is changed by "setting the property looplevel, which controls the solution parameter."
Example:
  • model.result('pg1').set('looplevel', 10);
  • model.result('pg1').run;
0 Replies Last Post 11 lug 2020, 00:04 GMT-4
Hello Behzad Sadrfaridpour
