Robert Koslover
Certified Consultant
4 years ago
30 lug 2020, 17:00 GMT-4
Updated:
4 years ago
30 lug 2020, 17:02 GMT-4
Hmm. I didn't see a point-setting option for the temperature offered. I found that you can specify a heat source boundary condition on a point, but apparently not a fixed temperature boundary condition. Well, how about a work-around then, since true point-constraint conditions aren't physical in the real world anyway! Yes, there's probably a better way, but it's been two weeks since you posted this question and no one answered. So here's my two cents: If I was in a hurry, and I simply wanted to specify the temperature at a "single point" within a 3D volume, I would probably just put a tiny sphere there (instead of a true point) and specify the temperature on its surface (which is a legitimate boundary). Similarly, if I wanted to specify the temperature at a single point in a 2D model, I would probably just put a tiny circle there (instead of a true point), and specify the temperature on its edge (again, which is a legitimate boundary). For a small enough sphere or circle, the physics calculations of interest to you (at least, in most real-world problems that I can imagine) would be equivalent. Right? Good luck.
Dave Greve
4 years ago
31 lug 2020, 12:57 GMT-4
More > Pointwise Constraint then Constraint Expression T-273 (to set T to 273).
You may need to enable advanced physics options to see this. Works for edges also, where, for some reason, it is also called Pointwise Constraint.
Robert Koslover
4 years ago
31 lug 2020, 15:07 GMT-4
Hi Dave. Hmm, I had to look for that one! Right-click "Heat Transfer in Solids" or similar, then Show More Options..., then under Physics, click the box to show Equation-based Contributions. OK. Then go back to right-click on Points, and choose Pointwise Constraint.
Henrik Sönnerlind
COMSOL Employee
4 years ago
31 lug 2020, 17:13 GMT-4
Dave,
The term Pointwise Constraint is not related to the dimension of the geometrical object to which it is applied,
The constraint is pointwise in the sense that it is applied to all individual mesh nodes in the selection. The opposite is a weak constraint.
Henrik Sönnerlind
COMSOL
Dave,
The term *Pointwise Constraint* is not related to the dimension of the geometrical object to which it is applied,
Dave Greve
4 years ago
1 ago 2020, 13:24 GMT-4
Yeah, definitely not easy to find. I think I turned it up by looking at some examples on this website. One of the ways to find out how to do things that are not obvious.
I was suggesting that Edgewise Constraint would be more informative.
