Rotating Particle Inlet
The problem is about the Particle Tracing Module. For the introduction of the particles I use the Release from grid
option. If the formulation is Newtonian, I'm allowed to introduce in the user-interface the (q0x,q0y) coordinates of the inlet point and the corresponding initial velocity of the released particle. But, while this latter can be expressed parametrically (and for instance in function of time), the coordinates are fixed. On the contrary, in my specific problem-application, I have an inlet which rotates!
How to implement that ? (It would be enough that the initial coordinates also would be allowed to change in time as it happens with the initial velocity expression...)
i46
0 Replies Last Post 28 feb 2012, 12:56 GMT-5
Hello i46
