Doesn't COMSOL accept complex interpolation functions?
It seems so...
I have to define the real and imaginary parts separately.
4 Replies Last Post 3 mar 2012, 06:39 GMT-5
Posted: 1 decade ago 2 mar 2012, 17:49 GMT-5
I did so by writing like this:
real(f)
imag(f)
where f is the desired function. For example, in my work, I wanted to plot a function which was frequency- dependant. But, I just needed to plot the real part. So I defined it as above in Global Expressions and plotted it easily!
I did so by writing like this: real(f) imag(f) where f is the desired function. For example, in my work, I wanted to plot a function which was frequency- dependant. But, I just needed to plot the real part. So I defined it as above in Global Expressions and plotted it easily!
Posted: 1 decade ago 2 mar 2012, 17:52 GMT-5
Thanks for ur reply!
But I don't get ur point... I mean define a function from complex data.
Thanks for ur reply! But I don't get ur point... I mean define a function from complex data.
Posted: 1 decade ago 3 mar 2012, 05:03 GMT-5
you can always enter the ral and complex part separately and combine tem in the equations or with an anlytical function (do not forget to turn on the "can produce Complex data from real arguments)
Test it out with a simple eample to be 100% convinced ;)
I believe it worked also like that in 3.5
Hi you can always enter the ral and complex part separately and combine tem in the equations or with an anlytical function (do not forget to turn on the "can produce Complex data from real arguments) Test it out with a simple eample to be 100% convinced ;) I believe it worked also like that in 3.5 -- Good luck Ivar
Posted: 1 decade ago 3 mar 2012, 06:39 GMT-5
Thanks, Ivar!
I think this is the way to get around the problem.
Thanks, Ivar! I think this is the way to get around the problem.
