Saving accumulated probe table at time steps taken by solver?
I am doing a parametric sweep on my studies and am interested in the results recorded by a few probes. When running without the sweep, I select to update probe results at the times taken by the solver; however that probe table gets overwritten at every iteration of the sweep. Accumulated table instead only saves the probe results at times stored at output. To get higher resolution, I have to increase the number of time steps of the output, which hugely increases my model size as it saves everything at that resolution.
Is there a way of outputing the accumulated probe table at times taken by the solver instead?
1 Reply Last Post 28 set 2020, 11:55 GMT-4
Hello Rapolas Daugintis
Posted: 5 years ago 28 set 2020, 11:55 GMT-4
Dear Rapolas,
I am facing the same problem. Did you manage to find a solution?
Thank you very much
Daniele
Dear Rapolas, I am facing the same problem. Did you manage to find a solution? Thank you very much Daniele
