Out of memory error during parametric sweep
I am running a parametric sweep on a model which takes up a lot of RAM.
I usually get an 'out of memory' error after about 10 study steps. However, if I run the parametric sweep with fewer steps over the same range it works fine.
Does anyone know how to approach this type of problem?
Many thanks in advance!
5 Replies Last Post 6 mar 2012, 16:33 GMT-5
Posted: 1 decade ago 6 mar 2012, 12:42 GMT-5
Try increasing Java Heap size. There is a KB article on how to do it.
Posted: 1 decade ago 6 mar 2012, 13:14 GMT-5
Thanks for your reply.
I have tried increasing the heap space to 10GB without any luck so far.
Do you have any other suggestions?
Thanks for your reply. I have tried increasing the heap space to 10GB without any luck so far. Do you have any other suggestions?
Posted: 1 decade ago 6 mar 2012, 13:20 GMT-5
It worked for me.
Of course you can always try to decrease DoF, it would definitely help with out of memory error. How many DoF do you have and what's your RAM size?
It worked for me. Of course you can always try to decrease DoF, it would definitely help with out of memory error. How many DoF do you have and what's your RAM size?
Posted: 1 decade ago 6 mar 2012, 14:45 GMT-5
Decreasing the DoF by modifying the mesh has helped, however I really need to use a finer mesh. The simulation that worked had around 200000 DoF in every step of the sweep and Comsol never used more than about 5 GB of ram. There was plenty of free RAM in any case even in the simulations that didn't work.
Aside from the java heap space do you know if there is anything else that I can change which will allow me to use more DoF?
Decreasing the DoF by modifying the mesh has helped, however I really need to use a finer mesh. The simulation that worked had around 200000 DoF in every step of the sweep and Comsol never used more than about 5 GB of ram. There was plenty of free RAM in any case even in the simulations that didn't work. Aside from the java heap space do you know if there is anything else that I can change which will allow me to use more DoF?
Posted: 1 decade ago 6 mar 2012, 16:33 GMT-5
No, sorry. Try contacting support.
