5 years ago
25 ago 2020, 02:16 GMT-4
If you simulate transport of charged species, a better option is to use Nernst-Planck equation in, e.g. Tertiary Current Distribution node that computes electric potential in the liquid phase and ionic transport in an electric field. Coupling electrostatic field to tranport is not sufficient because ionic transport has a contribution in the field, i.e. diffusion potential.
5 years ago
3 set 2020, 02:02 GMT-4
Updated:
5 years ago
3 set 2020, 05:46 GMT-4
Thank You for your Answer. However, I need to define the space charge density on part of the domain by using FCD. it is the three layer membrane, and on the middle one there is a (Space charge density) that I need to define. When I start using Nernst-Planck, I could not find any boundary condition to define that Fixed charge density. That is why I try couple electrostatic with solute transport module ( through Nernst-Planck-Poisson) is much better for my problem, which gave me different result with activate/deactivate the Multiphysics.
Do ou have any idea, how I can define fixed charged density in Nernst-Planck module?
I really appreciate your help,
5 years ago
4 set 2020, 01:49 GMT-4
There is an option Ion Exchange Membrane where you can insert fixed charge density. I am currently using it with success.
Lasse
Lasse
5 years ago
6 set 2020, 03:30 GMT-4
Thank you. I am trying to find tertiary node under Nernst-Planck equation, but could not find it.
Do you mind let me know where exactly is the tertiary node in Nernst-Planck equ?
5 years ago
7 set 2020, 03:32 GMT-4
It is under electrochemistry node. Do you have it?
Lasse
Lasse
