3.5 and 4.1 solver difference?
I have a model, which can be solved in 4.1.
The same setting in 3.5, then the model doesn't converge.
I load the 3.5 version model in 4.1 and add a new study. It converge again.
Who knows the difference between the solvers in 3.5 and 4.1?
2 Replies Last Post 9 mar 2012, 23:57 GMT-5
Posted: 1 decade ago 9 mar 2012, 21:32 GMT-5
which of the solvers you use? what are the settings? if you are using default, they might be different.
Posted: 1 decade ago 9 mar 2012, 23:57 GMT-5
You are right. The 3.5 is using the PARDISO, while 4.1 is using MUMPS.
I am coupling electrostatics, Nernst-Planck with Navier-Stokes equation.
When just with electrostatics and nernst-planck, 3.5 can give a correct answer.
Also with just using Navier-Stokes equation, 3.5 is fine too.
However, when I coupled them together, 3.5 didn't converge and said that the error is beyond tolerance.
You are right. The 3.5 is using the PARDISO, while 4.1 is using MUMPS. I am coupling electrostatics, Nernst-Planck with Navier-Stokes equation. When just with electrostatics and nernst-planck, 3.5 can give a correct answer. Also with just using Navier-Stokes equation, 3.5 is fine too. However, when I coupled them together, 3.5 didn't converge and said that the error is beyond tolerance.
