12 mar 2012, 04:43 GMT-4
that COMSOL version is really too old for me to remember, but normally all data entry fields (or almost) accept functions,so its mainly "just" to enter the function as is (use the correct coordinate x,y,z or r depending on your model
13 mar 2012, 00:02 GMT-4
Thanks for your reply. But I still don't understand. You mean I should create a new function f(x) in the "Function" submenu under "Physics" menu, and then what? The height of the columnar object is 1500 nm, so the ionic mobility is different along the height of the object according to the function f(x).
13 mar 2012, 02:27 GMT-4
if you have a height along the "z" coordinate, then you can write mobility = mu_value if the mobility is constant, but you acn also write in mobility = mu_value0+mu_slope*(z-z0) in the equation in this way it will vary linearly with Z, it's just to adapt to get any desired function
