Constructing laser light source
Hello all,
As light source in my real life setup I have a Helium Neon laser emitting light at lamba = 632[nm] with a spotsize of 0.8[mm].
In Comsol I want simply (as start) to let this light propagate from vacuum (refractive index = 1) into a block of glass (refractive index ~2).
What is the simplest way to 'construct' this laser light source? (I'm currently using version 4.2a)
Kind regards,
Arjan
1 Reply Last Post 12 mar 2012, 11:31 GMT-4
Posted: 1 decade ago 12 mar 2012, 11:31 GMT-4
if you are at the beam waist, you can use a Gaussian amplitude profile and a flat/plane E field and let that propagate. This should give you about an "gaussian" beam propagation of your laser energy
Hi if you are at the beam waist, you can use a Gaussian amplitude profile and a flat/plane E field and let that propagate. This should give you about an "gaussian" beam propagation of your laser energy -- Good luck Ivar
