COMSOL quits silently
the COMSOL quits silently after working of 1 year with this software with the same PC, I even reinstall my windows but I still have problem. I do not really know what I should do.
12 Replies Last Post 16 feb 2016, 10:45 GMT-5
Posted: 1 decade ago 12 mar 2012, 17:41 GMT-4
I had similar problems couple weeks ago after upgrading to the most recent Java Runtime Environment. I had to uninstall this Java update and after that COMSOL is working fine again.
Posted: 1 decade ago 12 mar 2012, 19:42 GMT-4
Thanks, I did as you said, but I still have that problem, I am really confused. I do not know whether it is a hardware problem or not?
Posted: 1 decade ago 13 mar 2012, 02:49 GMT-4
that happens time to time also to me (win7-64) not sure why, I have tried to change different issues int he OS, with the AV no succes, suddenly it start to work OK again. It's always linked with the "hs_err_pidnnn.log" of the type
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x0000000077190895, pid=1620, tid=3860
# JRE version: 6.0_20-b02
# Java VM: Java HotSpot(TM) 64-Bit Server VM (16.3-b01 mixed mode windows-amd64 )
# Problematic frame:
# C [ntdll.dll+0x50895]
So I beleive its a COMSOL <=> Java <=> OS issue but I havent got further. Mostly it restart after having resinstalled the software, which luckily goes quick
Hi that happens time to time also to me (win7-64) not sure why, I have tried to change different issues int he OS, with the AV no succes, suddenly it start to work OK again. It's always linked with the "hs_err_pidnnn.log" of the type # # A fatal error has been detected by the Java Runtime Environment: # # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x0000000077190895, pid=1620, tid=3860 # # JRE version: 6.0_20-b02 # Java VM: Java HotSpot(TM) 64-Bit Server VM (16.3-b01 mixed mode windows-amd64 ) # Problematic frame: # C [ntdll.dll+0x50895] # # So I beleive its a COMSOL Java OS issue but I havent got further. Mostly it restart after having resinstalled the software, which luckily goes quick -- Good luck Ivar
Posted: 1 decade ago 13 mar 2012, 08:51 GMT-4
Thanks Ivar,
The wired thing is that I have been using COMSOL with the same PC and same OS (Win7, 64 bit) for one year and I did not have any problem. But starting 2012, this problem keeps happening. I did not change anything in my OS or even my PC.
Thanks Ivar, The wired thing is that I have been using COMSOL with the same PC and same OS (Win7, 64 bit) for one year and I did not have any problem. But starting 2012, this problem keeps happening. I did not change anything in my OS or even my PC.
Posted: 1 decade ago 13 mar 2012, 14:41 GMT-4
I think it's due to Java-COMSOL problems. I have JavaVM 6.0.230, and COMSOL has never crashed. It used to happen with earlier versions of Java but not very often to bother me. After installing the latest 6.0.3x JVM version it would crash every 10 minutes.
So what I would do is to uninstall both Java and COMSOL first. Then install JavaVM 6.0.230. After that, install COMSOL.
Hope this helps. Please let us know the result.
I think it's due to Java-COMSOL problems. I have JavaVM 6.0.230, and COMSOL has never crashed. It used to happen with earlier versions of Java but not very often to bother me. After installing the latest 6.0.3x JVM version it would crash every 10 minutes. So what I would do is to uninstall both Java and COMSOL first. Then install JavaVM 6.0.230. After that, install COMSOL. Hope this helps. Please let us know the result.
Posted: 1 decade ago 13 mar 2012, 16:36 GMT-4
I'm not sure COMSOL is using the OS installed Java or rather it's own one incorporated in the distribution, but still these two might interact negatively. I'm having my workstation do its "automatic" updates, but the failures, always unexpected, do not seem to line up particularly with either MS or Java updates, at least not in a easy to identify way
I had some crashes this morning, but these could be linked to my complex file ? as COMSOL restarted thereafter cleanly (but no longer when accessing that partcular file ;)
Hi I'm not sure COMSOL is using the OS installed Java or rather it's own one incorporated in the distribution, but still these two might interact negatively. I'm having my workstation do its "automatic" updates, but the failures, always unexpected, do not seem to line up particularly with either MS or Java updates, at least not in a easy to identify way I had some crashes this morning, but these could be linked to my complex file ? as COMSOL restarted thereafter cleanly (but no longer when accessing that partcular file ;) -- Good luck Ivar
Posted: 1 decade ago 14 mar 2012, 08:18 GMT-4
not, i try your method, it did't work. the crash remain with particular file.
i am running with 3D model.
not, i try your method, it did't work. the crash remain with particular file. i am running with 3D model.
Posted: 1 decade ago 14 mar 2012, 08:46 GMT-4
if it's with a given file then it must be the file that is corrupt (as I had yesterday) but when it does not allow you to restart COMSOL even without a file, then at least for me I can reinstall COMSOL and it works again) luckily this is seldom.
I'm currently tracking more carefully all automatic updates of my OS and of Java to see if i can find any correlation, but as it's not happening often it will take me some months ;)
in the mean time, what I like, it's quickly done to reconstruct a new model, even one with a few houndred domains
Hi if it's with a given file then it must be the file that is corrupt (as I had yesterday) but when it does not allow you to restart COMSOL even without a file, then at least for me I can reinstall COMSOL and it works again) luckily this is seldom. I'm currently tracking more carefully all automatic updates of my OS and of Java to see if i can find any correlation, but as it's not happening often it will take me some months ;) in the mean time, what I like, it's quickly done to reconstruct a new model, even one with a few houndred domains -- Good luck Ivar
Posted: 1 decade ago 14 mar 2012, 08:53 GMT-4
Dear All,
I found out that my problem was due to the memory, one of my memories was not working properly, I used this software to check my memories:
www.memtest86.com/download.html
and after that I remove one of me memory cards, aand now it is working. It was a problem with some bits in my memory that causes the COMSOL to quits silently.
Dear All, I found out that my problem was due to the memory, one of my memories was not working properly, I used this software to check my memories: http://www.memtest86.com/download.html and after that I remove one of me memory cards, aand now it is working. It was a problem with some bits in my memory that causes the COMSOL to quits silently.
Jon Ebert Certified Consultant
Posted: 9 years ago 3 dic 2015, 21:39 GMT-5
I was running a model on my laptop, and I've never seen this. Then tonight I tried running it on my bigger/faster desktop and I get this same Java failure. It happens every time at exactly the same time during a solution of a flow/temperature model. During SOLVE, when the first convergence plot is complete, and before the second convergence plot starts, COMSOL quietly crashes (with the Java log file like you showed).
I tried a number of things, including:
1. re-install comsol
2. update to latest java, and re-install comsol, and
3. remove java completely and re-install comsol (again).
4. run memory diagnostics (didn't find a problem).
None of this worked. It still halts at exactly the same time, every time. Without any Java installed, I still see from the log that COMSOL is using Java 7, so I'm guessing COMSOL is using it's own local version.
Hope this helps.
I'm using Win10, COMSOL 5.2, 64bit, CPU:total 16 (8 cores per cpu, 2 threads per core) family 6 model 63 stepping 2
Jon
I was running a model on my laptop, and I've never seen this. Then tonight I tried running it on my bigger/faster desktop and I get this same Java failure. It happens every time at exactly the same time during a solution of a flow/temperature model. During SOLVE, when the first convergence plot is complete, and before the second convergence plot starts, COMSOL quietly crashes (with the Java log file like you showed). I tried a number of things, including: 1. re-install comsol 2. update to latest java, and re-install comsol, and 3. remove java completely and re-install comsol (again). 4. run memory diagnostics (didn't find a problem). None of this worked. It still halts at exactly the same time, every time. Without any Java installed, I still see from the log that COMSOL is using Java 7, so I'm guessing COMSOL is using it's own local version. Hope this helps. I'm using Win10, COMSOL 5.2, 64bit, CPU:total 16 (8 cores per cpu, 2 threads per core) family 6 model 63 stepping 2 Jon
Niklas Rom COMSOL Employee
Posted: 9 years ago 4 dic 2015, 03:37 GMT-5
Hi Jon,
can you please submit a support ticket at www.comsol.com/support and attach any error log files.
Niklas Rom, COMSOL
Hope this helps.
Jon
Hi Jon, can you please submit a support ticket at http://www.comsol.com/support and attach any error log files. Thanks Niklas Rom, COMSOL [QUOTE] I was running a model on my laptop, and I've never seen this. Then tonight I tried running it on my bigger/faster desktop and I get this same Java failure. It happens every time at exactly the same time during a solution of a flow/temperature model. During SOLVE, when the first convergence plot is complete, and before the second convergence plot starts, COMSOL quietly crashes (with the Java log file like you showed). I tried a number of things, including: 1. re-install comsol 2. update to latest java, and re-install comsol, and 3. remove java completely and re-install comsol (again). 4. run memory diagnostics (didn't find a problem). None of this worked. It still halts at exactly the same time, every time. Without any Java installed, I still see from the log that COMSOL is using Java 7, so I'm guessing COMSOL is using it's own local version. Hope this helps. I'm using Win10, COMSOL 5.2, 64bit, CPU:total 16 (8 cores per cpu, 2 threads per core) family 6 model 63 stepping 2 Jon [/QUOTE]
Posted: 9 years ago 16 feb 2016, 10:45 GMT-5
I have recently installed and beginning use with COMSOL 4.4 I have been facing problem since I launch the software, it silently quits or crashes at times. Not able to start basic work also yet! Kindly advise
system configurations:
win 8.1 64bit, 6GB RAM, dual core, No graphics card, java latest installed
Thanks in anticipation.
Hi, I have recently installed and beginning use with COMSOL 4.4 I have been facing problem since I launch the software, it silently quits or crashes at times. Not able to start basic work also yet! Kindly advise system configurations: win 8.1 64bit, 6GB RAM, dual core, No graphics card, java latest installed Thanks in anticipation.
