Pawan Soami
COMSOL Employee
5 years ago
21 set 2020, 08:26 GMT-4
Hello Osama,
There are many ways to model such problem. The suitable physics interfaces are Layered Shell and Shell (with Layered Linear Elastic Material) interfaces. The Shell interface is based on equivalent single layer theory and faster compared to Layered Shell interface.
Regarding the impact modeling, either you can use Contact between the two bodies or to start with you can also use a impulse force applying directly on the composite plate. This force as a function of time can give approximate representation of the real contact force between the plate and hemisphere.
In case contact modeling is necessary here then using penalty method within contact sometimes simply the problem definition at the expense of slight inaccuracy. So you can try switching to penalty method if it is not used already.
Feel free to reach comsol support for any further help support@comsol.com.
Pawan Soami
Hello Osama,
Pawan Soami
Osama Ahmed
Ph. D Student
5 years ago
21 set 2020, 16:43 GMT-4
Hello Pawan,
Thank you for your reply. Yes I'm using the penalty method and contact modeling is necessary. I used the layered shell physics--> applied fixed boundary condition to two edges of the composite plate and tried to add a perscribed velocity condition to the hemisphere but I get " not applicable message"
Hello Pawan,
Pawan Soami
COMSOL Employee
5 years ago
22 set 2020, 13:48 GMT-4
Hello Osama,
I am afraid that it is difficult to suggest anything without seeing the model setup as fundamentally I don't see why such a model should throw an error.
Feel free to contact comsol support for further help.
Pawan Soami
Hello Osama,
Pawan Soami
