Error in sweep
Sachinthana Pathiranage
I'm running a Electromagnetic Wave, Frequency Domain simulation where in the parametric sweep, frequencies are defined by giving the wavelength. My simulation works fine for some wavelength range, say any wavelength above 5um however, when I try to run this for wavelenths below 5um, I get the following error for some wavelengths. Can someone kindly explain me the possible reason for this?
Error in sweep. The following feature has encountered a problem:
Undefined value found. - Detail: Undefined value found in the equation residual vector. There are 1 degrees of freedom giving NaN/Inf in the vector for the variable comp1.ewfd.S1x. at coordinates: (0,0), ... There are 1 degrees of freedom giving NaN/Inf in the vector for the variable comp1.ewfd.S2x. at coordinates: (0,0), ... - Feature: Stationary Solver 1 (sol1/s1)
P.S. I have included all the boundary conditions considered in theory in the model.
0 Replies Last Post 20 set 2020, 20:50 GMT-4
Hello Sachinthana Pathiranage
