How to write several physics in a loop using LiveLink for Matlab?
Hi everyone,
I have a question related to the use of the LiveLink for Matlab. I am using COMSOL version 4.2a
In my problem I have to perform N models one after another. Each model uses two modules: heat transfer and pde. For each model, I run it and I save the results. In the next model, I add a geometric entity to which I need to assign another pde module, and the initial values for the other domains will be the results of the previous model. And so on until I reach the last domain.
I am trying to do this using the LiveLink for Matlab by performing a loop. At each loop the COMSOL model is run and results are saved. At each loop, a geometric entity is added as well as a new PDE node. This PDE node will be called 'cN', being N the loop number.
For adding geometric entities I have no problems and it works. However, I am having trouble to add new PDE nodes to assing to different domains... I am trying something like this:
for j = 1:N
c_j = ['c',num2str(j)];
model.physics.create('c_j', 'CoefficientFormPDE', 'geom1');
end
But I think this is not working... Plus, inside each PDE I will have the same equation. However, the variables need to be different. For example, I need to have variable 'V1' for PDE 'c', variable 'V2' for PDE 'c2', and so on... I have thought about defining a variable node for each domain. I would then have to write a group of variables 'varN' at each loop. I am trying something like this:
for j = 1:N
var_j = ['var',num2str(j)];
model.variable.create('var_j');
end
I have also tried something like: model.variable.create(num2str(var_j));
or even
model.variable.create('',num2str(var_j),'');
Does anyone have some ideas about how I can solve this?
Any help would be appreciated, thank you!
Hope I was clear about my question...
Ana Gaspar
0 Replies Last Post 13 mar 2012, 09:04 GMT-4
Hello Ana Gaspar
