Question defining frequency as a parameter in RF module
Posted 17 mar 2012, 14:15 GMT-4 RF & Microwave Engineering 4 Replies
Hi all,
I’m working on modeling the electric field of a gold nanowire under an incident electric field and I’m trying to set it up so I can change the frequency without having to manually change the dielectric constant in the materials section. I know the equation I have to use, but I’m having a bit of trouble actually getting it to work with the model.
The equation in question is ε=1-ωp2/ω(ω+iγ), with γ and ωp being constants that I have numbers for. What I’ve done is defined those two as parameters (currently under global definitions) and then further defined ω as another parameter with value 0. I then set a range for it in the “Step 1: Frequency Domain” node under Study 1 and also in “Parametric 1”. I put the equation as the value for the dielectric constant under its materials node.
The problem is that when I try to run it, I get either empty parameter errors or “undefined value found” errors with notes about large degrees of freedom giving NaN/Inf in the vector. I suspect that I’m only supposed to have ω defined one place, but I’m not sure how to do it and still have it work in the dielectric function I put in.
Basically, I’m having some trouble with defining parameters and how to use them in the model itself. Any help is appreciated.
4 Replies Last Post 22 mar 2012, 03:39 GMT-4
