COMSOL programming
I want to import XYZ coordinate file in .txt or .csv format for genrating interpolation curve. The coordinates file name will change for each iteraction (example: 1.txt, 2.txt, ...nth.txt). Can I write for loop for calling filename in comsol java script. Please help me.
thanks Kiran
1 Reply Last Post 30 dic 2020, 13:41 CET
Hello Kiran Kabothu
Posted: 5 years ago 30 dic 2020, 13:41 CET
You can use method editer to import the data from .csv file. but the imported data is in string format. you need to convert the string to double. You can use following code for import the .csv file in COMSOL: String[][] data = readCSVFile("Path of the csv file");
