Units in Finite Element Computations in COMSOL
Hi I would like to ask when I set the geometric dimensions as millimeters, what do I need to set for the unit of Young's modulus? still Pa? or others? Best wishes J
2 Replies Last Post 23 nov 2020, 09:56 GMT-5
Posted: 4 years ago 20 nov 2020, 20:00 GMT-5
As long as you write the material constants with units, Comsol will take care of the conversion.
Posted: 4 years ago 23 nov 2020, 09:56 GMT-5
If you just write numbers, without explicit units, they are assumed to have the unit that is shown to the right of the text field. These default units are affected by the unit system selection that can be made both at the top level (root) node and for each Component node. Thus, different components can even have different unit systems.
Henrik Sönnerlind
COMSOL
