Hard drive space
How do I set it so that the space on the C drive is not reduced when calculating? In other words, how do I set up the resulting file from a calculation to another hard drive partition?
1 Reply Last Post 3 dic 2020, 03:05 GMT-5
Posted: 4 years ago 3 dic 2020, 03:05 GMT-5
Using Preferences->Files you can set which directories Comsol uses.
You can also set these directories using the command line. Open the Reference Manual and look for "The COMSOL Commands" to see these options.
Lars Gregersen
Comsol Denmark
Using Preferences->Files you can set which directories Comsol uses. You can also set these directories using the command line. Open the Reference Manual and look for "The COMSOL Commands" to see these options.
