Heaters on/off system
Posted 15 dic 2020, 05:18 GMT-5 Electromagnetics, Heat Transfer & Phase Change, Parameters, Variables, & Functions Version 5.6 1 Reply
Hello dears,
My question is it possible to model a device/function in Comsol that controls when Heat Source should on/off depends on the temperature of the system. For example I want to keep specific object in temperature range and o If the specific object is operational, heaters should turn on if temperature drops below -15 C and then turn off once it’s above -10 C.
Maybe somebody had same issue and could assist on it? Thank you in advance for any information that could be useful to solve this task.
