Defining flow fluctuation
Hello everyone,
I am using comsol for particle tracing in a microfluidic separation device where I am using a laminar flow profile with a constant flow rate. But I want to check if any flow fluctuation can affect my separation efficiency. If its true, then I want to find out upto how much fluctuation is acceptable for my device. Therefore, I want to add a flow fluctuation profile at the inlet. Is it possible to do that in Comsol, to add a flow fluctuation? My basic idea is that these flow fluctuation will induce pressure fluctuation which should affect the separation efficiency.
Thanks a lot. Your help would be much appreciated.
1 Reply Last Post 10 feb 2021, 12:35 GMT-5
Hello Md Ehtashamul Haque
Posted: 4 years ago 10 feb 2021, 12:35 GMT-5
Hello
You can run a Parametric Sweep by defining inlet velocity as a parameter in COMSOL. That will run simulations for multiple flow rates. But these would be individual runs for constant flow rates.
If you want to do a time varying flow rate in a single simulation, you can always define an interpolation function if you have the desired profile.
Hope this helps!
Hello You can run a Parametric Sweep by defining inlet velocity as a parameter in COMSOL. That will run simulations for multiple flow rates. But these would be individual runs for constant flow rates. If you want to do a time varying flow rate in a single simulation, you can always define an interpolation function if you have the desired profile. Hope this helps!
