Robert Koslover
Certified Consultant
4 years ago
29 dic 2020, 14:38 GMT-5
You need to integrate your current density across a cross-sectional surface (presumably one normal to it). There are a number of ways to do that. If you don't already have that surface defined in your problem, you can add a 3D cut-plane. You can do such integrals post-solving. Go to Results --> Derived Values, right-click on that and choose Integration, then Surface Integration, then choose Cut Plane 1 from the Dataset pulldown under Data in the Settings panel. Alternatively, you can also set up Probes that integrate quantities of interest over various surfaces that you specify.
