Defining volume of cavity
I am solving the problem given in the following link: ( www.comsol.com/blogs/modeling-hydrostatic-pressure-fluid-deformable-container ). Can anyone please tell me how has the volume of the cavity been defined? I tried integrating with the intop1 operator (selected the boundary of the hyper-elastic material and computed with revolving geometry on), but intop1(1) gives the boundary area. If I select the domain of the balloon, it would give the volume of the material, which we don’t want, right? I'm a beginner, please help me out.
3 Replies Last Post 5 gen 2021, 14:41 GMT-5
Posted: 4 years ago 5 gen 2021, 10:43 GMT-5
Hello Sharique,
See https://www.comsol.com/blogs/computing-controlling-volume-cavity/ .
Jeff Hiller
Hello Sharique, See https://www.comsol.com/blogs/computing-controlling-volume-cavity/ . Best regards, Jeff
Posted: 4 years ago 5 gen 2021, 14:23 GMT-5
Updated: 4 years ago 5 gen 2021, 14:24 GMT-5
Thank you, Jeff.
In this model, the area of the cavity has been found. In a 2D-axisymmetric arrangement (such as the one in original query), selecting the interior boundary and choosing the 'compute with revolving geometry on' option, should give me the volume of the cavity for the expression AreaInt(-z*solid.nz), isn't it?
Thank you, Jeff. >See https://www.comsol.com/blogs/computing-controlling-volume-cavity/ . In this model, the area of the cavity has been found. In a 2D-axisymmetric arrangement (such as the one in original query), selecting the interior boundary and choosing the 'compute with revolving geometry on' option, should give me the volume of the cavity for the expression AreaInt(-z*solid.nz), isn't it?
Posted: 4 years ago 5 gen 2021, 14:41 GMT-5
That's the idea, yes. You can check your implementation by using a toy geometry for which the analytical expression of the volume is known, like a sphere, cylinder, or cone.
Jeff Hiller
That's the idea, yes. You can check your implementation by using a toy geometry for which the analytical expression of the volume is known, like a sphere, cylinder, or cone. Best, Jeff
