How to assemble different solutions into one plot?
Posted 6 gen 2021, 02:08 GMT-5 LiveLink for MATLAB, API, Results & Visualization 0 Replies
Good evening Comsol community.
Can you please help me?I AM VERY NEWBIE. Is it possible to assemble several solutions into one and plot them?
In my problem I need to do a parametric frequency sweep. So I did it as follows:
*I run my model once with a frequency of 100hz with time ( 0, 0.001, 2). *Then I run the model again with a 120HZ with time (0, 0.001, 2) *Then I run the model again with a 140Hz with time (0, 0.001, 2)
HERE is the problem, I need to assemble the 140Hz with the 120Hz with the 100 Hz solutions and then show the results into one plot.The correct way is running the model at 100Hz from 0 to 2 secs, then assemble that solution with the next, from 2 to 4 secs with 120Hz, then assemble that solution with the next, from 4 to 6 secs with 140Hz.
Can you give me some thoughts please? Any suggestions?
I am working on this through Matlab and I found this in the documentation:
SET LINEARIZATION POINTS mphstate uses linearization points to assemble the state-space matrices. It may help me?
Thanks in advance.
Hello Victor Navarrete
