blood and plasma as material
hello, how to add blood and plasma as material in comsol. someone please give me your valuable suggestions. thanks
1 Reply Last Post 10 feb 2021, 12:13 GMT-5
Posted: 4 years ago 10 feb 2021, 12:13 GMT-5
Hello
You can define a blank material and give the Density and Viscosity associated with the fluid as material properties and add it in the user defined library. By adding in the user defined library you cal always pick it up next time withour redefining.
Below link is a COMSOL Tutorial on the same
https://www.comsol.co.in/learning-center/creating-new-material-comsol-multiphysics#:~:text=In%20the%20COMSOL%20Multiphysics%C2%AE,your%20own%20completely%20customized%20materials.&text=You%20can%20also%20control%20the,a%20user%2Ddefined%20material%20library.
Hello You can define a blank material and give the Density and Viscosity associated with the fluid as material properties and add it in the user defined library. By adding in the user defined library you cal always pick it up next time withour redefining. Below link is a COMSOL Tutorial on the same https://www.comsol.co.in/learning-center/creating-new-material-comsol-multiphysics#:~:text=In%20the%20COMSOL%20Multiphysics%C2%AE,your%20own%20completely%20customized%20materials.&text=You%20can%20also%20control%20the,a%20user%2Ddefined%20material%20library.
