Torsion simulation
I'm facing a problem in simulating a simple free-clampled beam for torsion .
How to simulate torsion moment at the free face of the beam ?
i have searched about this topic in the forum , but all proposed solutions were in 3.5 & i'm currently using comsol4.2
Thanks in advance
1 Reply Last Post 17 apr 2012, 14:26 GMT-4
Posted: 1 decade ago 17 apr 2012, 14:26 GMT-4
the same way applies to v4, OK the names change a little ;)
In v4 you also have the new "rigid connector" but it makes the boundary really "rigid" hence might give you some hot spots along the boundary.
I mostly prefer to apply a distributed force density in a cylindrical coordinate frame sys2 such that a global variable
Mf = integral_over_boundary(F(sys2.r)*sys2.r)
and then constrain this global variable in a weak way to Mf - MyMoment = 0
I believe I have a model from the ol 3.5 days in the model exchange, you could alwys load it into v4 and take a look, take care with the naming convention that has changed a bit with the v4 (r)evolution ;)
Hi the same way applies to v4, OK the names change a little ;) In v4 you also have the new "rigid connector" but it makes the boundary really "rigid" hence might give you some hot spots along the boundary. I mostly prefer to apply a distributed force density in a cylindrical coordinate frame sys2 such that a global variable Mf = integral_over_boundary(F(sys2.r)*sys2.r) and then constrain this global variable in a weak way to Mf - MyMoment = 0 I believe I have a model from the ol 3.5 days in the model exchange, you could alwys load it into v4 and take a look, take care with the naming convention that has changed a bit with the v4 (r)evolution ;) -- Good luck Ivar
