Gravity effect
Sorry for my newbie question. I'm trying to simulate 2D two-phase flow in porous media. I'm wondering whether COMSOL considers gravity effect when applying Two-Phase Darcy's Law physics.
Thank you,
Jiri
13 Replies Last Post 22 ott 2015, 08:24 GMT-4
Posted: 1 decade ago 19 apr 2012, 16:17 GMT-4
I'm not by my WS and I'm not using Darcy flow regularly, so I do not know for sure, but if it's possible it must come as a domain boundary load that you must add with a variable of the type "whatever_physics_tag".rho*g_const in the direction that is desired on your model.
As by default COMSOL does certainly not include a "turned on" gravity component, there i no way for COMOSL to know in which direction to apply any load, this is left to the users to define
Hi I'm not by my WS and I'm not using Darcy flow regularly, so I do not know for sure, but if it's possible it must come as a domain boundary load that you must add with a variable of the type "whatever_physics_tag".rho*g_const in the direction that is desired on your model. As by default COMSOL does certainly not include a "turned on" gravity component, there i no way for COMOSL to know in which direction to apply any load, this is left to the users to define -- Good luck Ivar
Posted: 1 decade ago 22 apr 2012, 13:21 GMT-4
Hi Ivar
Thank you for your quick reply.
There are two physics related to Darcy's law within Porous Media and Subsurface Flow: Darcy's Law (DL) and Two-Phase Darcy's Law (TPDL). The first one has the gravity component that can be literally turned on. Unfortunately, I cannot find anything related to gravity component within TPDL physics. I also noted that DL equations contain a gravity constant while TPDL equations not.
Thank you
Jiri
Hi Ivar Thank you for your quick reply. There are two physics related to Darcy's law within Porous Media and Subsurface Flow: Darcy's Law (DL) and Two-Phase Darcy's Law (TPDL). The first one has the gravity component that can be literally turned on. Unfortunately, I cannot find anything related to gravity component within TPDL physics. I also noted that DL equations contain a gravity constant while TPDL equations not. Thank you Jiri
Posted: 1 decade ago 22 ago 2012, 10:50 GMT-4
I have to include coriolis force and centrifugal force in Darcy's Law. I cannot figure out how to do that. please help. The author mentioned he knows how to include gravity in single phase . if would be helpful if he can tell how he does that.
Hi I have to include coriolis force and centrifugal force in Darcy's Law. I cannot figure out how to do that. please help. The author mentioned he knows how to include gravity in single phase . if would be helpful if he can tell how he does that. Thanks
Posted: 1 decade ago 22 ago 2012, 12:25 GMT-4
For the structure interface, the gravity is defined in "body force"
For fluid interface, the gravity can be defined in"volume force"
For the structure interface, the gravity is defined in "body force" For fluid interface, the gravity can be defined in"volume force"
Posted: 1 decade ago 21 set 2012, 13:46 GMT-4
I am a little bit confused. Are gravitational effects implemented?
Posted: 1 decade ago 21 set 2012, 14:32 GMT-4
gravity fores act on the domain as Body or "volume" forces, defined such as "material.rho*g_const" in [N/m^3] along the direction wanted (and g_const is COMSOL's internal name for 9.81[m/s^2] see the doc).
A centrifugal force can be applied the same way but you should then define a cylindrical coordinate frame and use a material.rho*sys2.r*omega^2 where omega is the rotation in as 2*pi*freq[1/s]
material.rho is the density of the active materials, it's a new synonyme to solid.rho or ht.rho ... generic for all physics, check the 4.3 doc
Hi gravity fores act on the domain as Body or "volume" forces, defined such as "material.rho*g_const" in [N/m^3] along the direction wanted (and g_const is COMSOL's internal name for 9.81[m/s^2] see the doc). A centrifugal force can be applied the same way but you should then define a cylindrical coordinate frame and use a material.rho*sys2.r*omega^2 where omega is the rotation in as 2*pi*freq[1/s] material.rho is the density of the active materials, it's a new synonyme to solid.rho or ht.rho ... generic for all physics, check the 4.3 doc -- Good luck Ivar
Posted: 1 decade ago 24 set 2012, 15:54 GMT-4
Thanks Ivar,
I don't see a way to define body or volume forces in this module. All that is included is values for saturation and fluid/matrix properties.
All boundary conditions are related with flux.
Also when I expand the "Equation", I see
u=-k/m grap (P),
while it should be u=-k/m grap (P+rho*g*grad(D)).
Thanks Ivar, I don't see a way to define body or volume forces in this module. All that is included is values for saturation and fluid/matrix properties. All boundary conditions are related with flux. Also when I expand the "Equation", I see u=-k/m grap (P), while it should be u=-k/m grap (P+rho*g*grad(D)).
Posted: 1 decade ago 25 set 2012, 10:41 GMT-4
you are right, no volume/body force here as in pure DL & TPDL you only solve for pressure, (I'm not often in these physics so I missed that one ;)
But you have it in FP, sh/could you use this one ?
Hi you are right, no volume/body force here as in pure DL & TPDL you only solve for pressure, (I'm not often in these physics so I missed that one ;) But you have it in FP, sh/could you use this one ? -- Good luck Ivar
Posted: 1 decade ago 7 mar 2013, 19:00 GMT-5
But if we use FP module , then by neglecting inertial term , we can only get down from modified NS equation to Brinkman equation. We can never get to Darcys law as the viscous term will still be there
Posted: 1 decade ago 4 mar 2015, 11:34 GMT-5
I have the same problem.
I want to use Darcy model but there is no volume force option!
Is it possible to add the volume force as weak contribution?
If yes, then how? Can you give the weak contribution expression.
Thanks in advance.
I have the same problem. I want to use Darcy model but there is no volume force option! Is it possible to add the volume force as weak contribution? If yes, then how? Can you give the weak contribution expression. Thanks in advance.
Posted: 1 decade ago 6 mar 2015, 06:18 GMT-5
Thanks for the post. I noticed a typing mistake in the equation.
u=-k/m grad(P), when the gravity turned off.
u=-k/m (grad(P)+rho*g). when the gravity turned on (g is gravity vector). This should be manually edited in the equation view...
Thanks Ivar,
u=-k/m grap (P),
Thanks for the post. I noticed a typing mistake in the equation. u=-k/m grad(P), when the gravity turned off. u=-k/m (grad(P)+rho*g). when the gravity turned on (g is gravity vector). This should be manually edited in the equation view... [QUOTE] Thanks Ivar, I don't see a way to define body or volume forces in this module. All that is included is values for saturation and fluid/matrix properties. All boundary conditions are related with flux. Also when I expand the "Equation", I see u=-k/m grap (P), while it should be u=-k/m grap (P+rho*g*grad(D)). [/QUOTE]
Posted: 1 decade ago 15 apr 2015, 15:12 GMT-4
I would like to know how to manually edit the equations because I am not able to find any option to edit the equation. Your help is appreciated.
Thanks Ivar,
u=-k/m grap (P),
I would like to know how to manually edit the equations because I am not able to find any option to edit the equation. Your help is appreciated. [QUOTE] Thanks for the post. I noticed a typing mistake in the equation. u=-k/m grad(P), when the gravity turned off. u=-k/m (grad(P)+rho*g). when the gravity turned on (g is gravity vector). This should be manually edited in the equation view... [QUOTE] Thanks Ivar, I don't see a way to define body or volume forces in this module. All that is included is values for saturation and fluid/matrix properties. All boundary conditions are related with flux. Also when I expand the "Equation", I see u=-k/m grap (P), while it should be u=-k/m grap (P+rho*g*grad(D)). [/QUOTE] [/QUOTE]
Posted: 9 years ago 22 ott 2015, 08:24 GMT-4
Did you find how to apply Body force in Darcy's law
Zarghaam
Did you find how to apply Body force in Darcy's law -- Zarghaam
