About defining a TE/TM mode incidental light in 3D waveguide structure
Hi, everyone.
Since we know we can use a 2D cross-section of waveguide to fine the effective refractive index. Incident light at the designed port can be difined as "Rectangle" with TE/TM mode.
Here I want to do the simulation in 3D model. The type of port is "numeric" while there is no definition for the mode.
After boundary model analysis I got the field distribution in the cross-section.
I wonder whether I can define a TE/TM light to simulate in 3D model.
Thank you so much.
4 Replies Last Post 9 ott 2015, 06:39 GMT-4
Posted: 1 decade ago 25 apr 2012, 12:27 GMT-4
You can use Port>User Defined to specify manually TE and TM modes
Posted: 1 decade ago 29 apr 2012, 05:24 GMT-4
About defining a TE mode in 3D waveguide sturcture
Thank you so much for your guidance.
Now I will try to use "user defined " port.
However, if I want to use a 1W TE-polarized incidental light, what should I define on INPUT QUANTITY(like the initial value of electric fields and propogation constant?)
Thanks so much.
About defining a TE mode in 3D waveguide sturcture Thank you so much for your guidance. Now I will try to use "user defined " port. However, if I want to use a 1W TE-polarized incidental light, what should I define on INPUT QUANTITY(like the initial value of electric fields and propogation constant?) Thanks so much.
Posted: 1 decade ago 30 apr 2012, 16:21 GMT-4
It's explained in "Plasmonic Wire Grating" example
Posted: 9 years ago 9 ott 2015, 06:39 GMT-4
hey,
I'm having similar problems. I'm also trying to design a 3D waveguide model. Have you found the solution yet?
hey, I'm having similar problems. I'm also trying to design a 3D waveguide model. Have you found the solution yet?
