error 4100??
hi guys, I want to ask you about the error I found in my COMSOL, it's says:
Error: 4100
Failed to generate mesh for subdomain.
- Subdomain: 1
Failed to respect boundary element edge on geometry face.
- Face: 6
- x coordinate: -0.0228125
- y coordinate: 0.279526
- z coordinate: -0.0005
Internal error in boundary respecting.
So what should I do and why is this error happening? I want to make a structure using the composite objects, but this error come to the surface. Thanks for your attention.
1 Reply Last Post 26 gen 2010, 03:29 GMT-5
Posted: 2 decades ago 26 gen 2010, 03:29 GMT-5
often you can get around by meshing edges/faces by hand, removing "small" features in the geometry (if not relevant to the solution) or cut the volumes into smaller parts to allow the mesher to better adapt to complex geometry shapes.
Try also to change the default meshing size, or adapt it for the different parts
Try to understand where and what is getting wrong by studying the geometry around that coordinate (and any similar shaped element in your model).
Automatic meshing of complex geometries is not trivial, not even for a human ;)
Hi often you can get around by meshing edges/faces by hand, removing "small" features in the geometry (if not relevant to the solution) or cut the volumes into smaller parts to allow the mesher to better adapt to complex geometry shapes. Try also to change the default meshing size, or adapt it for the different parts Try to understand where and what is getting wrong by studying the geometry around that coordinate (and any similar shaped element in your model). Automatic meshing of complex geometries is not trivial, not even for a human ;) Good luck Ivar
