Solve a fluid flow problem in two diferent files.
Posted 17 feb 2021, 13:11 GMT-5 Fluid & Heat, Computational Fluid Dynamics (CFD), Particle Tracing for Fluid Flow Version 5.5 0 Replies
Hello, I am working in a fluid flow problem in a chemical reactors system in series, the two reactros are the same geometry. Each reactor is in a diferent file due to the ram memorie requirments. The question is, how to introduce the solution velocity profiles from the outet of the first reactor as a boundary condition to the inlet of the second reactor. It is a time dependent problem. I will appreciate your help!
Hello Jose Barragan
