converting COMSOL code to the MATLAB ???
I'm working with COMSOL to simulate a chemical experience, but it takes too much time to display the results.
So i want to find a link between comsol and matlab if i can convert the code of comsol to matlab that will be faster than using comsol alone !!!
So am asking if i can do this and how ????
watting your answer
thank you very much :)
5 Replies Last Post 1 giu 2012, 10:20 GMT-4
Posted: 1 decade ago 26 apr 2012, 09:31 GMT-4
you can simply save your comsol model as a MATLAB m.file
In the comsol file menu/ save As model mfile
Hi you can simply save your comsol model as a MATLAB m.file In the comsol file menu/ save As model mfile
Posted: 1 decade ago 26 apr 2012, 09:50 GMT-4
hi Mohammad ,
thank so much for your attention . i juste did what you say but when I execute the code in matlab, it doesn't work against in comsol it works very good !!
You can find out how I can solve this problem ?
thank's again
hi Mohammad , thank so much for your attention . i juste did what you say but when I execute the code in matlab, it doesn't work against in comsol it works very good !! You can find out how I can solve this problem ? thank's again
Posted: 1 decade ago 26 apr 2012, 10:00 GMT-4
Before executing the code in MATLAB, you should "run comsol with matlab"
go to the start menu/All programs/ comsol/ run comsol with matlab
then, you can run the mfile
Hi Before executing the code in MATLAB, you should "run comsol with matlab" go to the start menu/All programs/ comsol/ run comsol with matlab then, you can run the mfile
Posted: 1 decade ago 27 apr 2012, 15:09 GMT-4
here are the steps:
Step in Comsol:
- save model as .m
Start 'Comsol with Matlab'
Steps in Matlab:
- open the .m
- put first and last lines of the code in comments:
% function out = model
...code...
% out = model;
- at the end of the code, insert lines to extract results, here is an example for heat transfer, see the docs for mpheval:
T = mpheval(model,'T') % temperature
kx = mpheval(model,'ht.kxx') % thermal conductivity in x
- Run your .m (F5) and see the extracted data in the matlab workspace
- The postprocessing world is yours!
here are the steps: Step in Comsol: - save model as .m Start 'Comsol with Matlab' Steps in Matlab: - open the .m - put first and last lines of the code in comments: % function out = model ...code... % out = model; - at the end of the code, insert lines to extract results, here is an example for heat transfer, see the docs for mpheval: T = mpheval(model,'T') % temperature kx = mpheval(model,'ht.kxx') % thermal conductivity in x - Run your .m (F5) and see the extracted data in the matlab workspace - The postprocessing world is yours!
Posted: 1 decade ago 1 giu 2012, 10:20 GMT-4
Thanks.Good Hints.
Thanks.Good Hints.
