Pressure acoustics-Laminar flow-Particle tracing
I am trying to combine the 3 physics using 3 different studies. Frequency domain study for the pressure acoustics, stationary for the laminar flow and time dependent for the particle tracing. However, when I compute the 3rd study (tim dependent), I can only choose for the "Values not solved for" one of the studies and I always get an error. Why does this occur?
Thank you.
2 Replies Last Post 9 mar 2021, 11:32 GMT-5
Posted: 4 years ago 2 mar 2021, 16:14 GMT-5
Hi. You can solve the problem in the same study (single study) or you can solve it in three indipendent studies taking solutions from the previous studies using the command "withsol" (https://doc.comsol.com/5.6/docserver/#!/com.comsol.help.comsol/comsol_ref_definitions.17.026.html%231990211).
Posted: 4 years ago 9 mar 2021, 11:32 GMT-5
Hi Luigi,
Thank you for your reply.
Yes, I solved it in the same study using the "variables not dependent on" in each study!
Hi Luigi, Thank you for your reply. Yes, I solved it in the same study using the "variables not dependent on" in each study!
