electrical circuit conditions
i'm tring to studing the current distribution and juole losses in an indutor. I work with ac voltage sourge of 1000V with a frequency of 20kHz. i use an impedence boundary condition because my skin dept is so small. In my model i work with a lumped port connected with an electrical circuit. In the electrical circuit i define an voltage sorce and then an external I vs U (linked with my fem model). The model doesn't work and i get the the following error:"System matrix is zero".
Can someone help me?
Nicola
2 Replies Last Post 11 ago 2013, 09:48 GMT-4
Hello Nicola Gagliardi
Posted: 1 decade ago 11 ago 2013, 08:37 GMT-4
Hello Nicola
regarding the lumped port connected to the electrical circuit, I have the same problem,
i was wondering if you could inform me how to solve the problem, in case of finding a solution?
Sincerely
Behrooz
Hello Nicola regarding the lumped port connected to the electrical circuit, I have the same problem, i was wondering if you could inform me how to solve the problem, in case of finding a solution? Sincerely Behrooz
Posted: 1 decade ago 11 ago 2013, 09:48 GMT-4
Hi Nicola,
under the Stationary Solver node you have to specify Fully Coupled instead of Seggregated and you have to run a Direct solver instead of the Iterative. Then it solves without an error.
I should add that this is true in version 4.3b, in 4.2a you have to test it, I don't have it installed any more.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
Hi Nicola, under the Stationary Solver node you have to specify Fully Coupled instead of Seggregated and you have to run a Direct solver instead of the Iterative. Then it solves without an error. I should add that this is true in version 4.3b, in 4.2a you have to test it, I don't have it installed any more. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology
