initial solution problem
In a time dependent model I input a parameter as a function contains logarithmic part. put the program stopped at the initial step because there is a large difference between initial value and boundary value so the program give me fluctuated values beside the boundary ,where some values reaches to negatives .so the logarithmic part of the function gives error
1 Reply Last Post 12 mag 2012, 16:27 GMT-4
Posted: 1 decade ago 12 mag 2012, 16:27 GMT-4
I then believe you have no other way out than estimate better the solution from some hand calculations, and define your initial conditions closer to the final ones, and check that yourmesh is fine enough to orrectly solve the gradients you have, even (or probably specially) in log mode
Hi I then believe you have no other way out than estimate better the solution from some hand calculations, and define your initial conditions closer to the final ones, and check that yourmesh is fine enough to orrectly solve the gradients you have, even (or probably specially) in log mode -- Good luck Ivar
