Maximum stress location
Hi everyone, I have a simple question. I am trying to find a location of maximum stress on my model, but somehow I cannot find out how to get it. Can anyone please help me with that?
Josef
3 Replies Last Post 15 mag 2012, 10:22 GMT-4
Posted: 1 decade ago 15 mag 2012, 09:46 GMT-4
search the FORUM for max( it has been discussed a few times, its also (slightly hidden) in the help files you need to call the max(u,x), max(u,y) or max(u,z) to get the three coordinates x,y,z of the maximum of your dependent variable "u" (example for a solid physics case)
Hi search the FORUM for max( it has been discussed a few times, its also (slightly hidden) in the help files you need to call the max(u,x), max(u,y) or max(u,z) to get the three coordinates x,y,z of the maximum of your dependent variable "u" (example for a solid physics case) -- Good luck Ivar
Posted: 1 decade ago 15 mag 2012, 10:13 GMT-4
Thank you for fast answer. I did find a post about it, however I don't know how to do the following
Define a Maximum coupling operator, then pass in the independent variables as a second argument to query the location at which the maximum occurred. For example, say you solve for temperature, T, and you have a Maximum coupling operator, maxop1, then use:
maxop1(T,x) for the x-coordinate at which the maximum occurs
maxop1(T,y) for the y-coordinate at which the maximum occurs
Can you please tell me where exactly I do this?
Thank you
Josef
Thank you for fast answer. I did find a post about it, however I don't know how to do the following Define a Maximum coupling operator, then pass in the independent variables as a second argument to query the location at which the maximum occurred. For example, say you solve for temperature, T, and you have a Maximum coupling operator, maxop1, then use: maxop1(T,x) for the x-coordinate at which the maximum occurs maxop1(T,y) for the y-coordinate at which the maximum occurs Can you please tell me where exactly I do this? Thank you Josef
Posted: 1 decade ago 15 mag 2012, 10:22 GMT-4
the first argument is the variable (T(x,y,z,t) in your case, but you write just T) and the second argument is a charachter "x", "y" ...
Once you have defined the maxop1() operator in the definition, you must solve your model (or update it if already solved before you defined the maxop1)
Then under Derived Values you define a global value and enter maxop1(T,x), duplicate it 2-3 times and replace the x, by y then z respectively
The result in the table should be the coordinates of the maximum over the domains, or boundaries defuned under the maxop1() operator tab
Hi the first argument is the variable (T(x,y,z,t) in your case, but you write just T) and the second argument is a charachter "x", "y" ... Once you have defined the maxop1() operator in the definition, you must solve your model (or update it if already solved before you defined the maxop1) Then under Derived Values you define a global value and enter maxop1(T,x), duplicate it 2-3 times and replace the x, by y then z respectively The result in the table should be the coordinates of the maximum over the domains, or boundaries defuned under the maxop1() operator tab -- Good luck Ivar
