Robert Koslover
Certified Consultant
15 mag 2012, 23:13 GMT-4
If you haven't already done the following, consider this: After you click on the "geometry" level in the Model Builder, you should be able to find a little button among the row of buttons at the top of the screen that is the "select box" button (just hover the mouse cursor over them until you find it). Orient your geometry in a convenient way, click that button, then use the mouse to select large numbers of surfaces at once.
16 mag 2012, 09:12 GMT-4
you can also define several views and remove some of the entities from the view, then it's easier to select in complex models. You can play with the Definition selection lists too particularly for complex models. On the FORUM somewhere I described an nice way to use the view and selecting view suppressions to fill in selection lists for materials
16 mag 2012, 12:41 GMT-4
Under your help, I have made it.
Thank you very much!!
